Steamingandy
Timeing a Stuart triple is often considered a black art, this is hopefully shows one of the the problems that I think gets overlooked,the drawings have a note on them stating “if the ports vary from the drawings adjust the length of the valve to suit”.
This engine shows exactly why this is important
To the drawings the port positions require the Valve to be 0.625” long
This engine has both inlet ports larger, lower 0.022” over size and the upper 0.060” over size total of 0.082”.
So the valve for this cylinder is 0.707” instead of 0.625”
The exhaust port is to size so valve is machined to drawings.
Hopefully this clear enough to understand with the pictures.
