Stuart D10 - First test run
Patrik
Hi,
This is my first ever test run on compressed air. It's a Stuart D10
[ame]http://www.youtube.com/watch?v=eis14SMeZtQ[/ame]
patrik nice job and a good runner, keep up the good work . thanks for showing. jonesie
I'd be very pleased if that were my first run on air! :big:
Are you holding the top down because not everything is screwed together?
Simon
Thanks for the comments!! ;D
Simon, everything was bolted together, but I had to hold my pinkie and index finger on the expansion links so the engine didn't change direction. The drag links wasn't finished at that time. ;)
Okey, so I thought why not show you the pictures I do have during the build progress?
I did not own nor had access to a mill in the beginning of the project, that's why I used the lathe in some of the steps where maybe it would have been easier in the mill.
Here we go:
This is the first photo i have on the build:
IMG_0070 by Iccccie, on Flickr
Gland nut threading:
IMG_0073i by Iccccie, on Flickr
Trail fit:
IMG_0075i by Iccccie, on Flickr
Progress so far, this crankshaft had to be remade because the diemensions from the plans did not match up with my soleplate ???
IMG_0338 by Iccccie, on Flickr
Big end first drilled the bolt holes then cut in half:
IMG_0435 by Iccccie, on Flickr
Then milled both pieces flat:
IMG_0436 by Iccccie, on Flickr
Then drilled in steps and finally reamed:
IMG_0444 by Iccccie, on Flickr
Drilled the little end in same setting so i would get the two holes parallel. Half the little end was drilled to a larger dia and also reamed so the wristping could go in from one side and threaded in the other end:
IMG_0445 by Iccccie, on Flickr
Here you can see the different sizes:
IMG_0448 by Iccccie, on Flickr
Turned the shoulders:
IMG_0451 by Iccccie, on Flickr
Opened up the little end:
IMG_0457 by Iccccie, on Flickr
Finnished connecting rod:
IMG_0458 by Iccccie, on Flickr
Eccentric straps bored to final size:
IMG_0478 by Iccccie, on Flickr
Drilled and tapped the cylinder:
IMG_0054 by Iccccie, on Flickr
Centering the steam chest in the 4-jaw chuck using kozo's wiggler:
IMG_0082 by Iccccie, on Flickr
Gland boss turned and centre drilled, later drilled, reamed, drilled again and tapped:
IMG_0086 by Iccccie, on Flickr
Finnished steam chest:
Centering the eccentric:
IMG_0103 by Iccccie, on Flickr
Parted off and faced:
IMG_0111 by Iccccie, on Flickr
Steam chest gland nuts:
IMG_0112 by Iccccie, on Flickr
Milling the expansion links, yes both in the same run:
IMG_0129 by Iccccie, on Flickr
Valve with valve adjuster
IMG_0142 by Iccccie, on Flickr
New crankshaft:
IMG_0181 by Iccccie, on Flickr
Some more progress:
IMG_0189 by Iccccie, on Flickr
Steam inlet pipe in place:
IMG_0193 by Iccccie, on Flickr
And thats all for build photos!
I hope you have enjoyed it!
Nice work Patrik!
I like like it!! Thanks Patrik and please continue to post up your progress.
BC1
Jim
Nice, thanks for the post - I bought that kit over a year ago and got sidetracked doing other things - so I appreciate anything you post on that motor.
nice runner.
Ken
What exactly was the mismatch between crank and soleplate dimensions that caused you to remake the crank ?
As I mentioned earlier - I have that kit - forewarned is forearmed.
Ken
Hey Patrik,
You've been reading!....great technique...and smart "old school" set ups
I like it.....a lot!
:bow:
Nicely done!
Thank you all for your nice comments! Means a lot! ;D
I will provide you with updates as soon as i get more time on this project!
Ken
Ken,
I can't remember the exact number but I think it was around 1mm.
I should point out that this was only one of the reasons for rebuilding the crankshaft, it got a little bent during the clean up process (didn't know it was so delicate :-[ ) And also, the first soleplate i got (the one i built the crank after) was full of hardspots and did not machine very well, so i contacted Stuart models and received a new soleplate with better dimensions. Always had good support from Stuart Models!!! Cheers to that!
So your soleplate doesn't have to be out of dimension, but to be sure - check it. Lay out the holes for the stands and it will pretty much show if the soleplate is in dimension or not!
file.php
file.php
Thanks very much for the detailed reply.
My Stuart is very much on a back burner - I found this site after I ordered the kit - decided to build Gerry's beam engine first just to see if my skills held up before ruining the Stuart.
Since then I have been sidetracked designing and building engines that piqued my fancy (V4 Wobbler, Improbable inside out radial and I'm working on designs for an elbow engine and another inside out radial).
But when I do get to it I hope I manage as well as you, keep up the great postings.
Thanks,
Ken
She's a beaut! I love the fact that Stuart uses a lot of cast iron in their sets. I've built a couple of Tiny Power steam engines from castings, and while they are very nice, the all-bronze and brass doesn't look as nice (IMO) as the contrast you get with brass, bronze, and cast iron.
With an engine that nice, the paint is going to be a big deal. I may have missed it, but are you going to airbrush enamel?
