Stan said:Jan Ridder has a lot of stirling plans but they are also in metric. His plans and notes are in English and Dutch. Try this link
http://heetgasmodelbouw.ridders.nu/index.htm
Stan said:Metric is not that big of a problem. Spend half an hour with a pocket calculator and then change the dimensions on the plan to whatever is the closest screw/shaft/ bushing etc that you use. For example, if you are working in fractions, use a 1/8" (.125) instead of 3mm (.118).
