I am not sure if an IR pyrometer would work correctly or not.
I will have to research using that type with aluminum.
Some folks make their own pyrometers, and that can be done on a budget.
I have not made one, but they look relatively easy to make.
The connection point of the leads to the thermocouple can affect the accuracy of the pyrometer, but it is not really necessary to have an accurate temperature reading, but rather a consistent reading, so you can find a temperature that works well, and then duplicate that temperature, regardless of what that may be.
Generally aluminum 356 pours in the 1,350 F range.
Some go a little cooler, and some a little hotter, depending on whether the casting is thick or thin.
Here is one potential pyrometer that perhaps could be adapted to be a submersible type.
I see folks purchasing a piece of graphite rod, drilling a hole partway through it, and putting the thermocoulple inside.
The graphite is attached to a piece of electrical conduit, or similar steel tubing.
The wiring that goes to the thermocouple needs to be high temperature, and I think the white braided material is high temperature.
They also have round ceramic insulators that can be used on the hot end.
No guarantees as to how well this would work.
I need to research the home-built pyrometers a bit more.
