Ok I can only find the one unbuilt still in the box, and the half built I picked up at a garage sale.
Prominently on the front of the box
With the instruction book and foam padding removed
needs some clean up,and touch up haven't hydro the seams yet
Looking up the flue there is about 1 ½" from the fire pan to the bottom of the boiler.
Now it does clearly state that you can use 50/50 soft solder. But it does also say that "you can get Stay-brite silver bearing solder and stay bright is a little stronger than 50/50 solder. However either one is adequate to assemble this kit".
3 to 3 ½ ounces of tap water.
Place about 2 teaspoons of STERNO in the fuel cup. There is a caution in bold type that only chafing dish fuel are the only fuel recommended for use in this boiler. And that other fuels may generate to much heat and cause the boiler solder joints to melt.
Boiler is 2"dia and about 2 1/4" long.
Yes it is very low pressure, so much so that if the engine isn't turning. One of the checks is to take off the silicon tubing. If there is a pop sound there is steam in the boiler and to continue in the checking steps!
glen
