J
JorgensenSteam
Guest
I am pulling this item out as a separate topic so as not to distract from Brian's great posts for his overcrank single cylinder, but as Tel mentions, maybe the port/valve/eccentric design needs a second look.
I generally enjoy the diversity of design and materials, and like to see where people go with their free-lance methods, but in this case, perhaps some additional discussion of the port/valve/eccentric will yeild some useful information, especially if a number of people decide to build the same engine.
Here is my slant on the port/valve/eccentric design.
I am not sure if this is correct, but certainly a beginning point for the start of a discussion.
Pat J
Edit: I took a try at layout out some ports, passages, and a valve for Brian's engine.
Not sure if this is correct, but maybe someone can check me and see if I am in the ballpark.
For the passages, some blank rods could be inserted into the three holes, and then holes drilled between the three holes, to get a larger and more complete passage.
These dimensions are approximate, so don't build off of any of this.
Pat J
