Hello all, I have been working on redrawing a set of plans of a compound condensing steam engine that I downloaded from the CSEE forum. I am scaling up the original plans by 1/3. In drawing them in a CAD system the piston only has about .045" clearance between the head and piston on either top or bottom. My question is: if I lengthen the cylinder so each end has say 1/4" clearance, will that adversley affect performance? It seems to me that .045" is just too close. Also at that close the piston will block the cylinder drains at full stroke. Any thoughts? Thanks in advance.
