looking for help or advise on getting a powerhouse ic engine started. i have run out of things to try and ideas. it has a hall ignition and i get good spark, timing seems to be right , and the ignition fires at top dead center. i also put on a real light spring on the intake, and exhaust vale is opening at bottom of stroke,i tried using what jerry howell used 30/70 ach to coleman fuel.and also straight coleman, but it will still not fire. i turn it over with a cordless drill and you can hear the exhaust. i do not know what the air and fuel settings need to be on the throttle body i have tried opening the air wide open and needle valve closed and then start turning it over and then open needle valve a small amount but it still will not fire. the plans call out for a .025 hole in the fuel spray bar and i opened it up to .028. i also tried spraying starting fluid into the air intake and still nothing.with sparkplug out and touching the cylinder and turning it over i get a nice blue spark.any ideas or suggestions would be greatly . once i get it running i will post a video. thanks jonesie started on a jerry howell farm boy so i hope to get this one running so i can paint or powder coat frame.
