Bernd
Another thread has been started on metric unit conversion and how best to convert dimensions from metric to imperial. In these discussions I haven't seen anything mentioned on hole size or thread conversions. Hole sizes are easy. Say you need to drill a 2.5mm dia., converted to inch would be .098". The closest would be a 3/32 (.09375). Ok not bad so far.
Now how about a tapped hole of M3. ??? What size drill and tap will match that or be close to it. ??? I'll bet Marv's got a program or some fancy way to figure this. :-\ Only other choice I see is a chart. How many have a chart for such a conversion? Ya, I thought so. So anyway back to the M3 tapped hole. The chart say's M3 X 0.5 (that's a 3mm tap and a 0.5mm drill for you newbie's) the equivalent imperial size is 5-40 tap and a #39 drill.
The reason I bring this up is I would like to build a couple of steam engines, but they have metric dimensions. The linear dimensions are fine. I just convert to inch and be done with it. Hole size as I stated above. But the screw sizes got me until I came across a chart. I reconfigured it in Word and uploaded. It's in the General Section under Standard & Metric Thread Sizes Table.
Hope this helps some of you guys out. Download it and print it out to have handy the next time you need to convert from one thread size to the other.
Bernd
Bernd
