Fascinating.... But Gentlemen, one needs a good grounding in Jargon to appreciate this one. The use of different names is confusing me a bit...? But I am an amateur, so please correct me where I am wrong?
I understand a "slot drill" to be a type of milling cutter - not a drill at all - probably 2 flute, without any end cutting face? And I thought it has sharp corners for making a sharp-cornered bottom to the slot? Or is this a "Side cutter"? A "more normal" twist drill maximises the swarf-clearance space, and uses the self-centring of the cutting tapered-end (118 degrees or whatever) to ensure only end thrust on the drill - effectively supported from bending by the material around the hole. Drills are notoriously bendy so should never be used for any side thrust - Or so I was taught? But the "slot drill" or "side cutting Mill" (correct jargon please?) minimises this side relief, as the swarf clears away on the non-cutting side of the cutting motion. The centre metal of a slot-drill is as large as practical for stiffness to overcome the bending of side thrust, with minimal swarf relief slots. The end face is simply relieved as it effectively never cuts with the side-motion (perpendicular to the axis of rotation) from the traverse of the metal past the tool. I have some with helical side cutting edges and some with straight cutting edges. Please can to help me by explaining "which" one is used "when"?
End mills, as earlier explained by a few of you, can make flat-bottomed holes - as I (and many other amateurs?) will have used them, but we all will have learned that they can wander unless introduced into a previously drilled starter hole. And they do clog easily as the swarf relief is not as large as a twist drill. I understand that end-mills should be used to make blind-ended slots, where you need the end-milling face to cut fresh metal before the side motion can be used to make the slot. Please teach me the correct application - as "self-taught is worth naught!" There seems to be some differences of opinion in the thread, that conflict with some contributors' ideas? But here (this thread) we amateurs (like me) need a clear advice on "when to use what" from experts. And not having a Tool and Cutter grinder, some of us buy second-hand or cheaper tools for the odd-job as most of our models are "one-offs" anyway. (Most of my tools are "hand-me-downs" and second-hand). Where we have a choice of tool, or want to buy the "correct one for purpose", we need to understand what the correct tool should be.
Thanks for your advice, we know it is all well intended,
