The plans that came with mine showed a neat jig for the crank, maybe they deleted it.
You turned the mains first and milled the throws to size.
The jig was a section of round shaft about 2 inch dia. You milled a slot through the center, across the face the same size as the crank throw. Then bored a hole in the slot down the length of the jig. The hole was offset from center the same as the throw on the crank or 1/2 the stroke. One of the mains went into the hole and the slot held the throw. Two small set screws came in from the side to lock the throw in the slot. The jig was then chucked in the lathe, putting the rod bearing on center.
Hope that makes some sense. Wish I'd taken a photo of it.
Greg
