- Jul 16, 2007
- 3,011
- 1,072
Gentlemen,
While making the drawings for the transmission I had mentioned in another thread I came to the realization that to make it even close to the original I would need to cut some splines. I can truthfully say that with all the tooling I have made I have never had occasion to make a spline cutter.
I calculated a size that would fit my project, not wanting to do this more than I have to, and set about making the tools. First I would need a cutter to make the broach and also to cut the shafts. I layed out what I needed, .375 diameter, 12 splines, .032 deep and .04 wide at the root. To make the splines rectangular I would need to make the cutter with an angle of 14.48* on one side, 14.5* should suffice.
I indicated and turned a piece of .375 drill rod, cutting the required angles on the sides. I then ground up a tool with a .156 radius on the end and used that to just clean up the bottom of the teeth. At this point I hand filed the required clearances on the cutter leaving a minute line at the cutting edge so that I could hone it with a diamond after the tool was hardened. The tool was then hardened and finished.
George
George
