Spark plugs with 3/16 x 40 thread.
Guys, I am looking for a delivery address for spark plugs with 3/16 x 40 thread.
Try Ebay
It hard one use model engines in 1930 to late 1950’s. The it was all glow plug with think is a odd size ¼" . There maybe 3/16" glow plug that with some work could be a spark plug.
It can be hard one to find
I would try what
stevehuckss396
Model Engineer Project of the Month Winner HMEM Supporting Member
Today at 5:17 PM
New
Add bookmark
#2
Same as #10-40. Rimfires are out there somewhere. I think
and modify to fit.
I can see that it will be difficult to get spark plugs of this type. I may drill out the spark plug thread and cut 1/4 x 32 threads. However, I still have a question about this. Does this thread have a flank angle of 60° or 55°?
60 degrees. 55 I believe is Whitworth
Where I live everthing is 60° unless it was made in the UK then bring out the dies 🎲.
I would check the plug
To see if 55° or 60° I like using this a pocket comparator. I have a 10X and about 6 disk only two I use.
The first has both 55° and 60°.
I only use this for threads on old British equipment and engines.
3/16 = .188
#10 = .190
Both 40tpi
#10 and 3/16 are basically the same thing. What am I missing? Why would you open it up to 1/4 inch? Just get a 10-40 plug.
I find and have plug in hand first then work out threading problem.
I was shown a model engine that use a brass insert in a aluminum head. The guy had this engine cross thread plug in and need a replacement. At time I was new to machine work to help him.
Bruno
In post 12 and 14 you have a picture of an engine and it has a spark plug, I assume that is the plug you are looking for otherwise I do not understand the photo's. I would like to see the plug so as to determine the thread length you need, ie measure it. The 10-40 plugs come in short reach and long reach (maybe an in between) depends on the head of your engine. By showing a picture of it along with a ruler showing the length of the thread, we can better understand what you need. I agree with Steve I see no reason to change the threads.
I hope the pictures say more than a thousand words.
The thread lengths of the two spark plugs are identical.
    482.9 KB
    920 KB
    932.6 KB
    931.3 KB
    890.4 KB
    847.6 KB
I've ordered two of these spark plugs from the Chinaman, I'm looking forward to seeing how long they have to swim before I get them.
The smaller the spark plugs become, the more costly they are. For 2 pieces ~ 36,-€.
