Damn Man!!! Go back and read the whole post. I've given you a verbal description. I've posted pictures. I've posted solid models!!! If you are too lazy or unwilling to read the whole post, then don't bother looking at it.---BrianI gotta say, I'm liking this alot. I'm looking forward to seeing a working model of this!
What are you going to drive with it?
Brian,If you look at it in terms of diameters, it is a 2:1 ratio.Brian
Brian,
I got that idea from watching the animation, - if you watch one of the legs on the spider carefully, it will move from one end of a slot to the other end of that slot (in one revolution) so that means the large wheel (slotwheel?) will have turned thru 180deg. So, 2 revs of the spider = 1 rev of the slotwheel and as far as I can see the case would be the same with with a two legged "spider" (if that's possible ), but I need to add that I could be wrong!
Anyway, you seem to have done a sterling job!
The ratio would still be diametral, like a gear with more or less theeth, the pitch only changes.
I wonder if the "surface speed" of the outer diameter of the driven wheel will maintain constant as it goes a complete revolution. I would think that there will be slight "speed ups" and "slows down" as the rollers travel along the different angle positions on the slots. It should be interesting to watch in slow motion.
I don't think so. If you look at the typical crossed universal joint, when it's at an angle, it accelerates and decelerates twice in each revolution.Angular speed will be the same. "surface speed" or surface footage will be diametrically relative... Larger the diameter, the higher the surface footage.
Yes--Send me your "real" email address on the "private message" function and I will send you a download link to the solids models.---BrianBrain... would you be willing to send me your solids to save me a little time playing with this?
