Most know about using sodium silicate for making core but it can also be used for molds too. Dry ice can use to set the sodium silicate. Do not put Dry ice a container or touch the Dry ice. It builds pressure over 800 psi and will burn your skin is so cold.
Place the Dry ice top sand and cover with plastic tarp. Then let setup
Both can found in local stores.
Great for just few good castings.
For a crucibles pipe cap it will not last a long time but can found at local stores. You need to make a handle to pickup the crucible.
The furnace can be a old charcoal BBQ and steel tube/pipe from a vacuum cleaner.
Parting powder just use baby powder.
Please be safe I did not cover the safety need in the foundry.
Mixing can done in a plastic bucket. Note is will setup without CO2 so use a bucket or container that can be through away.
