lazylathe
- Aug 27, 2009
- 1,284
- 6
Hi All,
As i get closer and closer to actually building something on the Myford, i found the need to grind some HSS cutters.
I looked around the forum and used Brian Rupnows method explained here:
http://www.homemodelenginemachinist.com/index.php?topic=5569.0
The tool looks the same, i copied the angles and it looks okay.
Now when i go to cut something it leaves tiny ridges in the finish and not a smooth surface.
I have the tool set on centre and am using the slowest cutting speed on the lathe, without using the back gears.
Tried making the radius slightly bigger, but that did not help either.
Also thought it might be vibrations so i removed the 3 jaw and tried a shorted bit in the collet but no change.
Any ideas on what should be the next step??
Thanks,
Andrew
Thanks,
Andrew
