Small steam Cars built
galglg
Active Member
*** If you think this is a good production posts, your posts are my motivation!
After completion of the picture
Video:
[flash=600,500]http://player.youku.com/player.php/sid/XNTY0OTQ4NDcy/v.swf[/flash]
Video:
Production start:
This is a static small metal car models, work is in place. Need to make part of a steering mechanism, arrangements engines,
fuel systems.
Start cutting the front axle
Production Steering Parts
Install shock mount
Synchronized steering rod production
Welding steering axle
Steering preliminary molding
Damping effect
Paste the front wheel bushings
Cutting the rear axle
Welded rear drive shaft
Front axle limit screw mounting
Replace the front axle cover
Rear Axle Production
Steering Parts
Test steering gear
Welding steering fixed set
Initial steering mechanism forming
Old and new steering wheel
Gearbox Production
齿轮箱制作
Welding gear box
Charming little steering wheel
Welded and fixed steering gear box
Attached to the steering shaft
Completion of the steering mechanism
Do some cutting drive
Reduction shaft production
Fitted with engines
Fuel tank production
I will take two Please. Very nice. I would take it you have done some sheet metal work before. Keep up the good work
That's pretty cool. I followed the last thread on this. It's cool to see the work behind the running car. I've never been good with sheet metal - I think you did a fantastic job!
This should also please the picture hungry!
