Being much more of a lurker than a contributor to this wonderful site i feel now the time is right to start working on a contribution for the near future.
Like most of you i've got more hobby's and interests then spare time with machine acces. I'm a teacher at a Secondary Vocational Eduction in the Netherlands, teaching mechanical engineering. Unfortunately at work the machineshop is used (read abused) quite alot, so i can't leave a setup standing for days and have to check every machine before i can machine something. :wall:
At home i don't have enough room, nor the required funds, to begin my own (hobby) machineshop. This in a nutshell is my dillema.
Now the introduction is over here are my questions:
One of my hobby's involve litle 50cc mopeds from Honda especially the SS50Z, see the attached pic, hhich i almost restored to its original state.
I would like to design a 1/2 scale version of it, almost every part of the real version has been measured and 3d CAD drawn by me. As far as my knowledge goes and i deemed necessary for the future. Of course many parts are still lying around for future reference.
For the simpler parts i can just scale them down by half but the surface area and volumes of course could give problems that way.
Because i want it to be a runner i need some advice.
1 Should i try to remain true to the scale in regards to bore and stroke (39,0 => 20mm and 41,3 => 20mm) wich gives it just over 6cc volume.
Or should i aim at a more traditional volume for example 5cc?
2 Should i then copy the cam lobes and valves with the same profile?
3 With some pain i could reproduce the original carb, but my guess is that most of the measurements are surface areas whereas the required air mixture volume demands even smaller quantities.
Perhaps i can test the engine with a carb know to work on a 5cc engine first and then try building my own carb.
4 Am i missing something here?
With kind regards,
Napoleonb
With kind regards,
Napoleonb
