Hi all,
Part of my BSMET program is to build a steam engine from plans we are given. This is to get us used to working with machine tools before we take on larger projects.
At the end of the semester, we "race" our engines and see who gets the highest RPM from the standard design. The standard design is single cylinder, double acting, 1.125" bore, 0.468" stroke, 4.000" rod. The record speed was in the 4000 RPM range. Destruction is not uncommon. The test is done under no load.
I'd like to design and build my own steam engine to test alongside all the others. To keep things 'fair' I have decided to keep the single cylinder and 1.125" bore. From there, it's pretty open ended.
Does anyone have experience building single cylinder "race" engines? I'm looking for wisdom regarding bore/stroke ratio and rod/stroke ratio. I'm also looking for ideas for adjustable timing systems that will hold up to the high RPM use. But most importantly, I'm just looking for guidance in finding designs that are proven to work, so I can learn from them.
