I haven't posted here for a while as other things have been taking priority. But I have started down the path of my next diesel, a 4cc opposed twin based on the wonderful piston/cylinder design of David Owen's - Owen Mate. Just for fun calling it the HOLLY OWEN OPPOSED TWIN - or HOOT for short ...
This will be my 13th engine (all diesels) built from scratch and my 4th multi-cylinder. The 60 degree Vee twin and the inline twin both based again on David's cylinder/piston/conrod setup run really nicely, so a flat twin should round this off nicely.
As with all opposed twins, the double throw crankshaft presents some challenges, either you make a built up shaft or have caps on the conrods - I have chosen what might be a simpler way, taking a bit of a leaf out of the inline twin.
To keep it simple - I have made a interconnect shaft which will locate snugly into a short rear shaft and at the front into the driving shaft, the interconnect shaft being only supported by the front and rear shafts. I have run this through my mind many times and cannot see why it won't work, hence the commitments in time to see if it does in practicality.
If it does, it will be a very simple engine to make, not much harder than a single, but with a lot less vibration, well that's the theory.
I haven't done any detailed plans, just sketches for the bits as I go along, but if anyone wanted to put it on CAD that would be terrific, as I think it would interest other builders down the track if it works.
The secret to it functioning as intended is I think the interconnect shaft, I have made the disc from spring steel which is super tough with drill rod for the pins, a very tight press fit. The only disadvantage is the thickness of the interconnect disc to get stability into the pressed in pins, means that the cylinders will be a bit more staggered than normal.
I note Brian Rupnow has a similar engine on the go too, terrific stuff ...
Ed
Ed
