Simonds Files
Bovine
I have the pleasure if using a Simonds file on the lathe to remove tooling marks and finish my work. The school had them in the tool room hid away.
The closest thing I can compare is cutting with a sharp knife. This file is a beauty. Light pressure and you can gently dress a piece. Put more pressure behind it and fine shavings are removed.
What files do you all suggest since I heard this company is no longer around?
Bovine,
They're still around:
http://www.simonds.cc/pindex.html
Also, the well known US company Nicholson has quality files:
http://www.apexhandtools.com/brands/nicholson_files/index.cfm
If you want a lot of basic info about files and their use you can select from a "File Selection Guide" drop-down menu on the left side of that page.
ENCO sells Nicholson and import files:
http://www.use-enco.com/CGI/INSRHM
KBC sells Nicholson and Simonds and others:
http://kbctools.com/usa/main.cfm
I know there are many other vendors, these are just two that I have used a lot since I started this hobby.
--ShopShoe
Simonds are super files I have one or two myself. My personal favourite are Stubs, perhaps better known for needle files they did make the larger ones.
They are very rare now though. I am fairly sure the company is no longer in business.
I think most Engineers have a favorite maker and indeed a favorite file but this is not a "mine is better than yours" thing it's more like a favoured musical instrument, A file is one of the most personal tools we use so it is not surprising that we get very attached to them. (And even lock them away sometimes)
Regards Mark
Mark,
There is another thread currently on Die Filers and one of the growing problems DF owners have is the availability of files made for DF machines, which are straight-sided and reversed draw. Are you aware of anyone in the UK still making such files?
Hi GWRDriver
Offhand, no, limited market I guess, left hand taps and dies are easy enough to get so why not reverse cut files. I would have thought that manufacturing them is little more difficult than a conventional one.
Regards Mark
Thanks Mark. No, I wouldn't think it any more difficult or costly than a conventional file, but it's definitely a function of demand. It's my guess that in due time enough demand will accumulate to make it feasible for one of the file Mfg's to do a run of DF files. In the meantime there will be the hope of discovering a hidden cache of NOS. I thought I might have run across such a cache a few years ago. I found a local industrial "surplus" liquidator which had a yards of shelves of NOS files, all Simonds oddly enough. But no die files among them.
Almost any new file will cut like the OP found, UNTIL some idiot starts see-sawing it
back and forth across the corner of a piece of steel.. :) Like the average high school
kid it the metal shop. :) I've seen it all to often.
Simond files are all made in Honduras now, they are not of the same quality as when they were made in Newcomerstown Ohio.
