I would like to learn more about "raising the dottle" or other ways of cleaning the joint. Do you mean to clean while the solder is molten? Or is it just a way of saying to clean thoroughly in advance?
So far, I think most will agree that with increasing practice, it will be possible to physically 'stick' two bits of similar or dissimilar metals together with silver solder. The real test is whether the joint is able to stand steam and possibly superheated steam. Reams of comments have filled the pages of books and whatever about 'boiler testing'. Whether we like it or not, boilers will leak- they might even follow what used to happen in full size- and blow up. The policy is to eradicate leaks as far as is possible.
In the joining process, we have obviously used the best materials and the best possible practices to attempt to not introduce both non metal.
I think that sort of introduces the subject. If we do a dummy test of our competences, and cut through our joint, we will find that it is not quite textbook.
From this, we can and should try to remove as many things which cause leaks as we can. Despite fluxes, cleanliness and whatever, we can try to remove as much rubbish that we introduce into the weld pool.
If we keep the weld pool molten, we can 'fish' the problems out with either a pin pointed torch flame which literally digs and lifts the air and inclusions to the surface.
To answer the question yet to be posed, can this be done with a blow lamp?
Well, I can't do it and I am something called or was called a Certified Welder or a holder of a City and Guilds Certificate in Motor Vehicle Restoration-m amongst a heap of equally useless qualifications.
I can or could - with a pointed flame lift the impurities which gives rise to most of the leaks which are our lot. With a broad -any old heating source, the answer from me- is no.- or you might be lucky. y
Does this make other views topsy turvy? Well make your boiler, fill it with water, double your pressure- under water- of course and judge the result.
Back to trying to dealing with jet lag, zillion bean counting entries in far more difficult problems.
Norman
