One of the reasons it took me over four days is my process. I did one joint at time. Lets take just center section. It is held together by screws, the surface area to be brazed had punch marks to keep a small distance for the braze to wick into. The entire metal was fluxed, I mix my flux so it is runny and can be brushed on. Part is set at slight angle and silver Braze laid against the joint. Heat applied under the joint and on the center section, minimal heat if any on the joint itself, I want the material hot. Finally the braze wicks in and if more is needed it is applied. I now take the part and set it on some firebrick that is not hot up on some spacers for air flow. I let it air cool, maybe an hour or until I can pick it up in my bare hand without burning myself. Next I have one of those slow cookers that is about a 1 1/2 gallons. In that is Sparax 2, 1 gallon. I clean the part first in warm water and a brass brush to get loose stuff off. Then in the warm pickle bath for maybe 10 to 20 minutes at most. When done with that it goes in to a water bath for a rinse, then a soda bath to neutralized the acid, then water to clean it all up for the next cycle. I am using a brush at each stage to clean off flux and oxidation. If you look at the forth picture over that is how each stage looks when I cool and before I clean. Fifth picture is cleaned and another part being brazed on.
Each end has three joints, each done with one sequence of above. If I count correctly there were 16 passes. It is important to flux everything not just the joint you are doing, you really want to keep everything clean all the time. Here is another picture showing stepped braze temp, the small piece was brazed on before the main box was worked on. Those parts and that center section got the highest melt temp silver braze. The next picture shows the top of one side being brazed, the silver braze was inside and the heat applied to the top and side, took lots of heat to get it to flow, you see the heat treat oven that took it up to about 1000 degrees F first. Those are clamps keeping the ends tight while the top joint is brazed. If not clamped the part would just warp out. Due to the thickness of the material it could not be screwed at the top so I used a custom clamp.
I have used citric acid for steel, never tried it with brass.
I am not sure what you mean by the copper colored - the braze material? The brass is kind of a copper color when it comes out of the Sparax. Also the color is somewhat dependent on the light used and if I used a flash. In the end it will get a light bead blast and then painted so any color of the metal will disappear.
Hope this answers your questions.
View attachment 114923View attachment 114924
