learninturnin
rusto
- Oct 29, 2015
- 7
- 3
Hello, and thanks for reading.
I am having an issue with my manual Sherline mill. The Z axis saddle nut has fallen out of alignment and I am having some trouble getting it realigned correctly. I can't find any documentation on adjusting it so I was hoping someone here may have experience fine tuning it.
In having fallen out of adjustment several things typically happen.
1) The headstock will jam and I can not lower the headstock.
2) When the headstock is near the bottom of the column, it will drop/stutter/skip a little, maybe as much as a millimeter as I am lowering it.
I have been adjusting the alignment through a combination of the gib and the three saddle nut adjustment screws. I just can't tell for example, what tightening the lower screw, vs tightening the upper screw, vs tightening the middle screw does. I am pretty sure that tightening say the lower screw should adjust the column movement as it goes down? But I can't really see any direct evidence of that.
Thank you very much for any insight.
Russ.
Russ.
