Hello Folks,
It's been a while since I posted - I'm afraid I'm one of those annoying very occasional users! ;D This is a great forum though - lots of excellent info around!
Anyway, I just picked up a new addition to my arsenal, a small sheet metal machine. It's a combination shear, slip roll press brake. Here it is:
It's rather a nice little machine, I like it a lot. It's only for light duty work, which is fine I don't anticipate doing a whole lot of sheet metal work. This can handle 10" wide sheets.
Anyway, as usual I have to go over it and give it a clean, and make sure it is all set up correctly before starting. My question is - is there any recommendations on setting the blades on a shear? (of course there are - but what are they?) Should there be a clearnace gap, does this vary for different materials, or should the shear blades be set to slightly rub as the cut is made?
The manual that came with the machine is not the best, and in any case I am looking for the voice of experience! I have done a little bit of sheet metal work in the past, but not much.
Thanks all!
Thanks all!
