Hi All,
I recently decided to build a small static engine as a diversion from my main engine and various cnc conversions. I have had in mind a project to build a large oscilator using multiple cylinders. Probably nine or twelve cylinders. In the meantime I want something to sit on the bench and make a noise so looked in the scrap bin and built this three cylinder.
It's a bit rough at the moment and needs to bed itself in but it works well on air. Dead slow is on 20psi and fast is on 70psi at the moment. Self starts at between 15 and 20psi. The noise is the air escaping through the ports that are open and the mating faces of the cylinders.
Julian.
Julian.
