Green twin---your system needs a dewatering manifold. That is simply four 3/4" o.d. steel waterpipes about four foot long with a thread on both ends of the pipes. arranged vertically against a wall. The tops of the pipes are connected with two elbows and a short coupler The bottoms are connected by two short couplers and a simple valve. this should be located fairly close to the compressor. The water in the air condenses in the steel pipes and runs down to the valve. Every time you turn on your compressor, crack the valves open and let the water out. You will be amazed at how much water collects and how dry your air will be.---Brian
