Yesterday, I started a new build. An engine with reverse. So far it hasn't gone well.
I thought it was time to invest in a few new tools in an effort to increase the precision of my work.
I picked up a Bestest indicator 15-0-15 0.0005" resolution, a new precision drill chuck and a #3 MT reamer. I reamed the female Morse tapers in the tailstock and the mill quill. I found out that the wobble when I was drilling with the mill was the old drill chuck, not the bearings in the mill. I'm glad I did not buy the bearings. Next I checked the alignment between the head and tailstock with a piece of drill rod between centers and my new indicator. The #4 MT in the headstock was wobbling. I ended up taking a light cleanup cut with my boring tool on the large end of the female taper and that solved that problem. After that, I was indicating in my vice with my new Bestest indicator Well I broke the contact needle and the threaded portion broke off flush with the plastic bearing. I looked and can buy the offending piece for $14 plus $10 postage, sheese.
Got to go, more will be posted later.
SAM
I finished up with one of my Harbor Freight indicators.
SAM
