My son and I sparked up the spot light on the front porch last night...throws a nice beam once it's focused!
It needed the following
The front bezel screw was rusted solid, so I cut it and then drilled it out and chased the thread. A new SS screw solved that problem.
One of the wire contact blocks was missing, so I cranked up the lathe and made a new one and got to put my filing rest to work making it square which it did wonderfully!
A new cord was donated from remnants of the mill rewire with a judicious snip of a un-needed ground wire....it being DC and all.
Cleaned and polished everything with my Daughter at 4 am this past Saturday. We're morning people...
Next is a halogen bulb. I would have to modify it to put the T4 in but I can get a version of a T3 with a BP15D socket...which I got which puts out 800 lumens vs the 320 in a standard 1076 bulb...and it only doubles the current draw from 2.1 to 4 amps....still a pretty easy draw.
I suspect it will be "sun like"....we should have fun torturing the neighbors some night this week I suspect..... ;D
