As someone who has yet to try this - your results look good, and I predict the next one will be perfect!
A quick google, one mob says it's a high grade mild steel another it's equivalent to 1040 another 1045
Yes Brian,John-I just machined some 4140 for a fixture a customer wanted. It is really, really tough stuff. I'm not sure you could machine it with HSS cutting tools. I used carbide endmills to shape the part. Very nasty stuff. I have used 12L14 for my last two crankshafts. As far as warpage of the crankshaft from internal stresses go, it is much better to use hot rolled steel bar (Commonly called A36 here) than cold rolled steel.
As luck would have it a mate of mine had some 1' round cold rolled 1144 he bought from Amazon a couple of years ago and gave me what he had left a 7" length.View attachment 112315
Milled it down flat and had another go.Cuts like butter. Problem with using the round is when I make the counter balance and fit them there will be a little day light showing in the corners .View attachment 112316
All done.
