Rupnow Engine Finished
Brian Rupnow
Design Engineer
Barrie, Ontario, Canada
This is my first sustained 20 minute run of the Rupnow Engine. I have installed a CDI electronic ignition on it, but it will run just as well with conventional points and a coil. I have designed and posted a slightly smaller carburetor which seems to give the engine more stable running characteristics. The complete build article with drawings can be found at http://www.homemodelenginemachinist.com/f31/rupnow-i-c-engine-governor-21176/
This is the current video.
Hi Steve, I'm well advanced on my build, mine is an air cooled version, and if I recall correctly, there are at least 5 others making them.
Paul.
  • Like
Reactions: gus
I'm building one as well Steve, but it's taking me a while. You already know what my next project is ;) and that one's going to take years...
  • Like
Reactions: gus
Looks & runs great Brian. But why do you not use a carburettor from a modelengine?? Or is a venturi just fine for that engine...I hope you understand me?
Hit and miss engines were not a throttled engine. A simple venturi carb was all they needed. Speed is determined by the governor setting.---Brian
  • Like
Reactions: gus
Hi Brian,
Gus is about to jump in and build this engine but the water is very cold and deep.
Gus may not chicken out. Now having fun running/tuning and really finishing up
Webbie.Sure hard to say goodbye to Webbie.
Will take a short break before jumping in. Keeping tab on Paul's thread.
I have posted a download link at the end of the original build thread that will get you all of the drawings to build this engine, either air cooled or water cooled, and either with conventional points ignition or cdi electronic ignition.
There is a total of 55 .pdf drawings
A great job Brian,
I have followed your build from the beginning & I am glad to see it running so well. The ball governor looks great when the engine is working. I would like to build the engine but I have put too much time into setting up & converting drawings for my current project to put it on the back burner.
Don.
