rotary table programming
DÉDÉ
QC CANADA
Hello.From QC Canada I am starting in this field. I am trying to operate my rotary table with a stepper motor. On MEMF, I found a program, I managed to correct an error line 12 for keypad.h it writes: exit status 1 missing terminating "character. I'm stuck and lost, I really need help . If anyone wants to answer me, I will give them all the details
thank you
Why don't you tell us a little more about the program and the problem you are having with it. How is it programmed? Is the program secret or can you share it here?
thank you
The "error: missing terminating '"' character" in C programming language occurs when there is a missing closing double-quote in a string literal.
To fix this error, make sure all string literals in the program have a closing double-quote.
Hello no the program is not secret. On the forum as I'm a beginner I didn't want to load too much. If I had an answer I would give him all the details. I found this program from 2009 it includes 240 lines
#include <Wire.h>
#include <LiquidCrystal_I2C.h>
#include <Keypad.h>
const byte/*
ROWS = 4;
const byte COLS = 4;
char keys[ROWS][COLS] = {
{'1','2','3','A'},
{'4','5','6','B'},
{'7','8','9','C'},
{'.','0','#','D'}
byte rowPINS[ROWS] = {11,10,9,8};
byte colPINS[COLS] = {7,6,5,4};
Keypad kpd = Keypad(makeKeymap(keys),rowPINS,colPINS, ROWS, COLS);
LiquidCrystal_I2C lcd(0x27,20,4); // set the LCD address to 0x20 for a 16 chars and 2 line display
//setup vars
const int stp = 12; //connect pin 12 to step
const int dir = 13; // connect pin 13 to dir
const int StepsPerRotation = 400; //Set Steps per rotation of stepper
const int TableRatio = 72; //ratio of rotary table
const int Multiplier = (StepsPerRotation * TableRatio)/360;
const int stepdelay = 1;
float Degrees = 0; //Degrees from Serial input
float ToMove = 0; //Steps to move
float Divisions;
float current = 0;
int Mode = 0;
void setup()
lcd.init(); // initialize the lcd
pinMode(stp, OUTPUT);
pinMode(dir, OUTPUT);
// Print welcome message to the LCD.
lcd.backlight();
lcd.print("Rotarye Control");
lcd.setCursor(0,2);
lcd.print(" CrankyTechGuy CNC");
lcd.setCursor(0,3);
lcd.print(" Copyright 2014");
delay(2000);
lcd.init();
Mode = GetMode();
void software_Reset() // Restarts program from beginning but does not reset the peripherals and registers
asm volatile (" jmp 0");
void rotation(float tm, int d)
if(d == 0)
digitalWrite(dir, LOW);
else
digitalWrite(dir, HIGH);
for(int i = 0; i < tm; i++)
digitalWrite(stp, HIGH);
delay(stepdelay);
digitalWrite(stp, LOW);
delay(stepdelay);
float GetNumber()
float num = 0.00;
float decimal = 0.00;
float decnum = 0.00;
int counter = 0;
char key = kpd.getKey();
lcd.setCursor(0,0);lcd.print("Enterees then");lcd.setCursor(0,3);lcd.print(" press [#].");
lcd.setCursor(0,30);lcd.print("Reset);
lcd.setCursor(8,2);
bool decOffset = false;
while(key != '#')
switch (key)
case NO_KEY:
break;
case '.':
if(!decOffset)
decOffset = true;
lcd.print(key);
break;
case '0': case '1': case '2': case '3': case '4':
case '5': case '6': case '7': case '8': case '9':
if(!decOffset)
num = num * 10 + (key - '0');
lcd.print(key);
else if((decOffset) && (counter <= 1))
lcd.print(key);
counter++;
break;
case 'D':
software_Reset();
break;
decnum = num / pow(10, counter);
key = kpd.getKey();
return decnum;
float GetDivisions()
float num = 0.00;
lcd.clear();
lcd.setCursor(0,0);lcd.print("Entersions then");lcd.setCursor(0,1);lcd.print(" press [#].");
lcd.setCursor(8,2);
while(key != '#')
switch (key)
case NO_KEY:
break;
lcd.print(key);
break;
case 'D':
software_Reset();
break;
key = kpd.getKey();
// num = 360/num;
return num;
int GetMode()
int mode = 0;
lcd.setCursor(0,1);lcd.print("Selectode");
lcd.setCursor(0,3);
lcd.print(" DIV[A] DEG");
while(mode == 0)
if(key == 'A')
mode = 1;
else if(key == 'B')
mode = 2;
lcd.clear();
return mode;
void loop()
if(Mode == 1)
Divisions = GetDivisions();
Degrees = (360/Divisions);
if(Mode == 2)
Degrees = GetNumber();
lcd.clear();
lcd.setCursor(0,3);
lcd.print("FWDEV CAN[C]");
while(key != 'C')
lcd.setCursor(0,0);lcd.print("POS:");lcd.print(current);lcd.setCursor(0,1);lcd.print("DPM:");lcd.print(DegreesetKey();
if(key == 'A')
if(current >= 360)
current = (current + Degrees)-360;
} else {
current = current + Degrees;
ToMove = Degrees*Multiplier;
lcd.setCursor(0,2);
lcd.print(" Moving ");
rotation(ToMove,2);
lcd.setCursor(0,2);lcd.print(" ");
lcd.setCursor(4,0);lcd.print(" ");
if(key == 'B')
if(current <= 0)
current = 360+(current - Degrees);
} else {
current = current - Degrees;
lcd.setCursor(0,2);
rotation(ToMove,0);
lcd.clear();
Compilation error: Keypad.h: No such file or directory L1 col 7
best regard André
#include <Wire.h>
#include <Keypad.h>
const byte/*
ROWS = 4;
{'1','2','3','A'},
{'4','5','6','B'},
{'7','8','9','C'},
{'.','0','#','D'}
//setup vars
float Divisions;
float current = 0;
int Mode = 0;
void setup()
lcd.backlight();
lcd.setCursor(0,2);
lcd.setCursor(0,3);
delay(2000);
lcd.init();
Mode = GetMode();
if(d == 0)
else
delay(stepdelay);
delay(stepdelay);
float GetNumber()
float num = 0.00;
int counter = 0;
lcd.setCursor(8,2);
while(key != '#')
switch (key)
case NO_KEY:
break;
case '.':
if(!decOffset)
decOffset = true;
lcd.print(key);
break;
if(!decOffset)
lcd.print(key);
lcd.print(key);
counter++;
break;
case 'D':
software_Reset();
break;
key = kpd.getKey();
return decnum;
float num = 0.00;
lcd.clear();
lcd.setCursor(8,2);
while(key != '#')
switch (key)
case NO_KEY:
break;
lcd.print(key);
break;
case 'D':
software_Reset();
break;
key = kpd.getKey();
// num = 360/num;
return num;
int GetMode()
int mode = 0;
lcd.setCursor(0,3);
while(mode == 0)
if(key == 'A')
mode = 1;
else if(key == 'B')
mode = 2;
lcd.clear();
return mode;
void loop()
if(Mode == 1)
if(Mode == 2)
lcd.clear();
lcd.setCursor(0,3);
while(key != 'C')
if(key == 'A')
if(current >= 360)
} else {
lcd.setCursor(0,2);
rotation(ToMove,2);
if(key == 'B')
if(current <= 0)
} else {
lcd.setCursor(0,2);
rotation(ToMove,0);
lcd.clear();
best regard André
Where did you copy this code from, can you supply web address? There is numerous errors in this code.
Line 1 remove */
Line 7 remove /*
Line 88 missing " at the end of Reset should be ("Reset");
Line 138 missing " at the end of Reset should be ("Reset");
Line 204 ?
That is just for starters maybe someone else will can step in with some more help?
<snip>
best regard André
I copied your code into my Arduino IDE, I compiled for Uno hardware. I fixed your missing quotes. Also a mis-spelled attempt to print degrees as degreesetKey.
#include <Wire.h>
#include <Keypad.h>
const byte /* */
ROWS = 4;
{'1','2','3','A'},
{'4','5','6','B'},
{'7','8','9','C'},
{'.','0','#','D'}
//setup vars
float Divisions;
float current = 0;
int Mode = 0;
void setup()
lcd.backlight();
lcd.setCursor(0,2);
lcd.setCursor(0,3);
delay(2000);
lcd.init();
Mode = GetMode();
if(d == 0)
else
delay(stepdelay);
delay(stepdelay);
float GetNumber()
float num = 0.00;
//float decimal = 0.00;
int counter = 0;
lcd.print("Reset");
lcd.setCursor(8,2);
while(key != '#')
switch (key)
case NO_KEY:
break;
case '.':
if(!decOffset)
decOffset = true;
lcd.print(key);
break;
if(!decOffset)
lcd.print(key);
lcd.print(key);
counter++;
break;
case 'D':
software_Reset();
break;
key = kpd.getKey();
return decnum;
float num = 0.00;
lcd.clear();
lcd.setCursor(0,30);lcd.print("Reset");
lcd.setCursor(8,2);
while(key != '#')
switch (key)
case NO_KEY:
break;
lcd.print(key);
break;
case 'D':
software_Reset();
break;
key = kpd.getKey();
// num = 360/num;
return num;
int GetMode()
int mode = 0;
lcd.setCursor(0,3);
while(mode == 0)
if(key == 'A')
mode = 1;
else if(key == 'B')
mode = 2;
lcd.clear();
return mode;
void loop()
if(Mode == 1)
if(Mode == 2)
lcd.clear();
lcd.setCursor(0,3);
while(key != 'C')
lcd.setCursor(0,0);lcd.print("POS:");lcd.print(current);lcd.setCursor(0,1);lcd.print("DPM:");lcd.print(Degrees); /*lcd.print(DegreesetKey())*/
if(key == 'A')
if(current >= 360)
} else {
lcd.setCursor(0,2);
rotation(ToMove,2);
if(key == 'B')
if(current <= 0)
} else {
lcd.setCursor(0,2);
rotation(ToMove,0);
lcd.clear();
This will compile. But I don't know if it will work as I may have the wrong libraries for LiquidCrystal and KeyBoard.
You might want to have a look around here too https://www.homemodelenginemachinist.com/threads/help-with-arduino-idexer.35108/, because the code that is posted above has the rounding error described in the other thread!
:) the version i am now using is not "cleaned up" and reversing the direction might be a bad idea, because to use stepper drivers with higher step count, some variables were changed form long to unsigned long.
Hi, DÉDÉ I use this you only need to change the level of the turntable (For example: 1:90, 1:72, 1:36 Etc.)
4x4 matrix keypad amd a 20 x 4 LCD. From Bruce.
https://www.homemodelenginemachinis...y-table-for-dummies.26744/page-24#post-376666
A4988 Stepstick/Pololu driver
5/2/2015
#include <Wire.h>
#include <Keypad.h>
const byte ROWS = 4;
{'1','2','3','A'},
{'4','5','6','B'},
{'7','8','9','C'},
{'.','0','#','D'}
LiquidCrystal_I2C lcd(0x27,20,4); // set the LCD address to 0x20 for a 16 chars and 4 line display
// SCL - A5, SDA - A4, VCC - +5, Gnd - Gnd
//setup vars
const int stp = 2; // connect pin D2 to step
const int dir = 3; // connect pin D3 to dir
const int StepsPerRotation = 400; // Steps per rotation of stepper NOTE the driver is set to Half step
const int TableRatio = 90; // 36 ratio of rotary table
const float Multiplier = 60.0000; //(StepsPerRotation * TableRatio)/360; // 400*90=36000/360 = 100
/*Use the following Multipliers for the indicated ratios
100 to 1 = 111.1111
90 to 1 = 100
72 to 1 = 80.00
60 to 1 = 66.6667
40 to 1 = 44.4444
36 to 1 = 40.0000
32 to 1 = 35.55556
8 to 1 = 8.8889
4 to 1 = 4.4444
float Degrees = 0; // Degrees from Serial input
float ToMove = 0; // Steps to move
float bob = 0;
int cho = 0;
void setup()
lcd.backlight();
lcd.print("Rotary Table Control");
lcd.setCursor(4,2);
lcd.print(" ");
lcd.setCursor(3,3);
lcd.print("90-1 Sep 2021");
delay(2000);
lcd.init();
cho = 0;
lcd.print("Enter Selection:");
lcd.setCursor(0,1);
lcd.print("Degrees = A");
lcd.setCursor(0,2);
lcd.print("Divisions = B");
lcd.setCursor(0,3);
lcd.print("JOG = C");
while(cho == 0)
key = kpd.getKey();
switch (key)
case NO_KEY:
break;
case 'A':
Degrees=getdegrees();
lcd.clear();
cho = 1;
break;
case 'B':
Degrees=getdivisions();
cho=2;
break;
case 'C':
Degrees=getjog();
lcd.clear();
cho=3;
break;
} // end case
} // end while cho=0
} // end setup
void loop() // MAIN LOOP
lcd.clear();
bob = 0;
lcd.setCursor(7,0);lcd.print("Total: ");lcd.print(bob,2); // total steps
lcd.setCursor(0,3);lcd.print("FOR=A REV=B X=C");
while(key != 'C') // C will return to start menu
lcd.setCursor(0,0);lcd.print(abs(Degrees),2);lcd.print((char)223);
key = kpd.getKey();
if(key == 'A') // FORWARD
bob = bob + Degrees;
ToMove = (Degrees*Multiplier);
printadvance();
if(key=='B') // REVERSE
bob = bob - Degrees;
digitalWrite(dir, HIGH); // pin 13
printadvance();
} // end while not C loop
lcd.init();
setup();
} // end main VOID
float getjog()
float Degrees = 0;
float num = 0.00;
lcd.clear();
lcd.setCursor(6,0);lcd.print("Jogging");
lcd.setCursor(0,1);lcd.print("A=1 B=10 C=100 Steps");
lcd.setCursor(0,2);lcd.print("Enter Degrees:");lcd.setCursor(0,3);lcd.print("OK = # ");lcd.print((char)60);lcd.print((char)45);lcd.print(" D");
while(key != '#')
switch (key)
case NO_KEY:
break;
case 'A':
Degrees = 1;
lcd.setCursor(14,2);lcd.print(Degrees);
break;
case 'B':
Degrees = 10;
break;
case 'C':
Degrees = 100;
break;
case 'D':
num=0.00;
lcd.setCursor(14,2);lcd.print(" ");
break;
key = kpd.getKey();
return Degrees;
float getdivisions()
float Degrees = 0;
float num = 0.00;
lcd.clear();
lcd.setCursor(0,1);lcd.print("Enter Division:");lcd.setCursor(0,3);lcd.print("OK = # ");lcd.print((char)60);lcd.print((char)45);lcd.print(" D");
lcd.setCursor(16,1);
while(key != '#')
switch (key)
case NO_KEY:
break;
lcd.print(key);
break;
case 'D':
num=0.00;
lcd.setCursor(16,1);lcd.print(" ");
break;
Degrees = 360/num;
key = kpd.getKey();
return Degrees; //num;
float getdegrees()
//int key = 0;
float num = 0.00;
int counter = 0;
lcd.clear();
//lcd.init();
lcd.setCursor(0,1);lcd.print("Enter Degrees:");lcd.setCursor(0,3);lcd.print("OK = # ");lcd.print((char)60);lcd.print((char)45);lcd.print(" D");
lcd.setCursor(15,1);
while(key != '#')
switch (key)
case NO_KEY:
break;
case '.':
if(!decOffset)
decOffset = true;
lcd.print(key);
break;
case 'D':
num=0.00;
lcd.setCursor(15,1);lcd.print(" ");
break;
if(!decOffset)
lcd.print(key);
lcd.print(key);
counter++;
break;
} //end case
key = kpd.getKey();
} //end while not #
return decnum;
} // end getdegrees
void printadvance() // print function
lcd.setCursor(6,1);lcd.print("Moving");
lcd.setCursor(4,2);lcd.print("Steps ");lcd.print(ToMove,0);
lcd.setCursor(13,0);lcd.print(bob,2);
rotation(ToMove,0);
lcd.setCursor(6,1);lcd.print(" ");
void rotation(long tm, int d)
for(long i = 0; i < tm; i++) // Problem Fix
delay(stepdelay);
delay(stepdelay);
5/2/2015
#include <Wire.h>
#include <Keypad.h>
{'1','2','3','A'},
{'4','5','6','B'},
{'7','8','9','C'},
{'.','0','#','D'}
//setup vars
100 to 1 = 111.1111
90 to 1 = 100
72 to 1 = 80.00
60 to 1 = 66.6667
40 to 1 = 44.4444
36 to 1 = 40.0000
32 to 1 = 35.55556
8 to 1 = 8.8889
4 to 1 = 4.4444
float bob = 0;
int cho = 0;
void setup()
lcd.backlight();
lcd.setCursor(4,2);
lcd.print(" ");
lcd.setCursor(3,3);
delay(2000);
lcd.init();
cho = 0;
lcd.setCursor(0,1);
lcd.setCursor(0,2);
lcd.setCursor(0,3);
while(cho == 0)
key = kpd.getKey();
switch (key)
case NO_KEY:
break;
case 'A':
lcd.clear();
cho = 1;
break;
case 'B':
cho=2;
break;
case 'C':
Degrees=getjog();
lcd.clear();
cho=3;
break;
} // end case
} // end setup
lcd.clear();
bob = 0;
key = kpd.getKey();
printadvance();
printadvance();
lcd.init();
setup();
} // end main VOID
float getjog()
float Degrees = 0;
float num = 0.00;
lcd.clear();
while(key != '#')
switch (key)
case NO_KEY:
break;
case 'A':
Degrees = 1;
break;
case 'B':
Degrees = 10;
break;
case 'C':
Degrees = 100;
break;
case 'D':
num=0.00;
break;
key = kpd.getKey();
return Degrees;
float Degrees = 0;
float num = 0.00;
lcd.clear();
while(key != '#')
switch (key)
case NO_KEY:
break;
lcd.print(key);
break;
case 'D':
num=0.00;
break;
Degrees = 360/num;
key = kpd.getKey();
float getdegrees()
//int key = 0;
float num = 0.00;
int counter = 0;
lcd.clear();
//lcd.init();
while(key != '#')
switch (key)
case NO_KEY:
break;
case '.':
if(!decOffset)
decOffset = true;
lcd.print(key);
break;
case 'D':
num=0.00;
break;
if(!decOffset)
lcd.print(key);
lcd.print(key);
counter++;
break;
} //end case
key = kpd.getKey();
} //end while not #
return decnum;
} // end getdegrees
rotation(ToMove,0);
delay(stepdelay);
delay(stepdelay);
The choice of the table ratio (in my opinion is the least problem), unless you use the controller with different rotary tables.
Plus we have so many stepper drivers that can do much higher microstepping resolutions than half, quarter or 8th steps.
The problem that the system is under certain conditions not going a full circle is still in this code.
ToMove variable is a float. That float value is then tranfered into the "void rotation(long tm, int d)" function as a long tm, meaning all digits after the comma are ignored by the stepper motor.
All provided I do not read the code wrong and mis something:
With a 4:1 ratio per degree you loose 0.4444 steps out of 4.4444.
When the division is 360 it will move 360*4 steps = 1440 steps.
It should move 400 steps per revolution and four motor revolutions for one table revolution 400 * 4 = 1600 steps. 160 missing steps for a cirlce makes 160/4.4444 = 36° give or take.
So the software will be 36° degrees off, when I want to cut e.g. a graduation scale (not a good thing).
Greetings Timo
When I wrote my (arduino) code for my dividing head some years ago- and after numerous computer crashes, I now no longer have the source code!-I calculated each step from scratch, as I figured that way I won't accumulate any error. Seems to work, I don't have any measurable accumulated error after a full 360 degrees.
Line 1 remove */
Line 7 remove /*
Line 204 ?
5/2/2015
#include <Wire.h>
#include <Keypad.h>
{'1','2','3','A'},
{'4','5','6','B'},
{'7','8','9','C'},
{'.','0','#','D'}
//setup vars
100 to 1 = 111.1111
90 to 1 = 100
72 to 1 = 80.00
60 to 1 = 66.6667
40 to 1 = 44.4444
36 to 1 = 40.0000
32 to 1 = 35.55556
8 to 1 = 8.8889
4 to 1 = 4.4444
float bob = 0;
int cho = 0;
void setup()
lcd.backlight();
lcd.setCursor(4,2);
lcd.print(" ");
lcd.setCursor(3,3);
delay(2000);
lcd.init();
cho = 0;
lcd.setCursor(0,1);
lcd.setCursor(0,2);
lcd.setCursor(0,3);
while(cho == 0)
key = kpd.getKey();
switch (key)
case NO_KEY:
break;
case 'A':
lcd.clear();
cho = 1;
break;
case 'B':
cho=2;
break;
case 'C':
Degrees=getjog();
lcd.clear();
cho=3;
break;
} // end case
} // end setup
lcd.clear();
bob = 0;
key = kpd.getKey();
printadvance();
printadvance();
lcd.init();
setup();
} // end main VOID
float getjog()
float Degrees = 0;
float num = 0.00;
lcd.clear();
while(key != '#')
switch (key)
case NO_KEY:
break;
case 'A':
Degrees = 1;
break;
case 'B':
Degrees = 10;
break;
case 'C':
Degrees = 100;
break;
case 'D':
num=0.00;
break;
key = kpd.getKey();
return Degrees;
float Degrees = 0;
float num = 0.00;
lcd.clear();
while(key != '#')
switch (key)
case NO_KEY:
break;
lcd.print(key);
break;
case 'D':
num=0.00;
break;
Degrees = 360/num;
key = kpd.getKey();
float getdegrees()
//int key = 0;
float num = 0.00;
int counter = 0;
lcd.clear();
//lcd.init();
while(key != '#')
switch (key)
case NO_KEY:
break;
case '.':
if(!decOffset)
decOffset = true;
lcd.print(key);
break;
case 'D':
num=0.00;
break;
if(!decOffset)
lcd.print(key);
lcd.print(key);
counter++;
break;
} //end case
key = kpd.getKey();
} //end while not #
return decnum;
} // end getdegrees
rotation(ToMove,0);
delay(stepdelay);
delay(stepdelay);
hello Bruce
when I test the program it tells me
best regard André
hello Bruce
best regard André
In the Arduino IDE, click on tools and then "manage libraries". When that is finished loading, use the search bar at the top right and search for "Keypad". There will be many that show up then. Scroll down until you get to "Keypad" and install that. It should clear up that error message.
DEDE
Send me an email at [email protected] with the rotary table ratio eg 90:1 and I will send you a working program. I have sent this program to well over 150 members over several years with no complaints.
Note, you will have to have the libraries installed.
Bruce W-S
The modification I posted in the previous thread keeps track of the error and as soon as one full extra step fits in, it will do one more step. So it is limping its way around. A little too less, little too less, little too much etc. At the end it ends up spot on. Awake gave the necessary instruction, so we could come up with a "sort of fix".
Calculation for each position might result in a small numerical error with the float numbers, depends how programmed. Possibly be very "academic" and difficult to spot. But an error of 4° or 10° on one revolution can ruin a gear and make the software useless.
