Runner
- Feb 10, 2011
- 124
- 17
Hi all,
it states here http://www.modeng.johnbaguley.info/Valve Gears/valvegear1.htm fourth paragraph, that for the Walschaert's valve gear, the return crank can be set using a simple jig and that the lengthy set up that specified by LBSC, et al, is unnecessary. However, it doesn't show how the jig is made and indicates that the return crank is set to a position relative to the valve gear design and therefore doesn't take into account any build up of tolerances as LBSC's method does. Also the latter (LDSC's) requires that the eccentric rod length be determined from this set up method.
Can anyone tell me how such a jig is made?
Thanks in advance.
Brian
Thanks in advance.
Brian
