slowtwitch
- May 2, 2012
- 10
- 0
Hello folks, As I have mentioned in another thread, I acquired an Emco 220 lathe. I really didn't need another lathe, but, the Emco 220 has some much needed goodies that I needed ;D
The 220 has a large chip bin, which means, I don't have to empty it after each part I make and a parts catcher......
It also has a through the spindle capability...no more cutting my stock to 9" lengths ;D The lathe also sits on a steel box which is filled with some type of cement....which gives it a solid mass to sit on....and lastly, it only cost $1500.00 !!!!!
Here's the lathe as I bought it....
The previous owner kept the control stand and control box for a router setup he's building. I did get most of the electronics..stepper drives, boards, etc. But, i'm not really going to use any of it, since I will be converting to Mach3 control.
Since the winter months are kinda of slow, I had time to work on it. I took the lathe completely apart to clean it up, but, also to check it's condition.
All in all it's in pretty good shape. I did have to replace the small bearings on the ends of the ball screws and the oil distribution block.
I also installed new proximity switches for my limit stops. I only use two switches, as it worked really will on my 120p. Here's some pics of the setup....
more pics of a naked lathe
Here's the lathe cleaned up and painted...
Some specs...
An ESS Smoothstepper. The breakout board is a PMDX 126, with a PMDX 107 for speed control. The VFD is a Hitachi WJ200 Vector drive, attached to a 2hp vector duty 4 pole motor. The computer mother board is a Foxcon H61S with a dual core processor and 2meg of ram.
and finally, here's a video of its first attempt at making parts.
[ame="http://www.youtube.com/watch?v=QTtSbpjyy2g"]http://www.youtube.com/watch?v=QTtSbpjyy2g[/ame]
I still have to adjust the offsets on the drills, as i kinda of did it by eye....I was anxious to see it make something
pete
Some specs...
pete
