Hi,
I'm in the process of restoring an old lathe and I've got to the stage where I want to remove the name tags and data labels in preparation for painting.
They are made of thin aluminium sheet appear to be held in place with round headed aluminium nails.
There was one tag which was so mangled that it won't be going back on so I used it to see how to best remove others.
I couldn't get a grip on the heads of the "nails" with a pair of pliers so I tried levering them off with a slim cold chisel. It worked OK but the plate ended up badly bent.
Is there a trick to getting them off?
If all else fails, I suppose the best way of removing them without damaging the tags would be to drill them out.
Also, does anyone know the correct term for the "nails" and where to get them from?
Thanks,
Alan C.
Thanks,
Alan C.
