- Dec 2, 2008
- 971
- 9
Yeah, I heard it. One of these days, after I tame the donkey, I will try my hand at an elbow.
There is no good reason to even consider an acute angle, but I actually like the oblique angle numbers. If you consider the bore/stroke ratio (10/12.3) is much closer to normal in the 135° configuration, with all of the benefit of reduced piston speed, better ring and bore wear, etc. A few years ago I built an similar engine with a 108° angle and it ran quite well in spite of my limited equipment and limited experience at the time.
It is next to impossible to experiment with the range of possible angles for an elbow type engine due to the number of parts that need to be modified. BUT! The geometry of the elbow engine is identical to that of a swash plate engine. Just imagine an invisible swashplate that is set at a 45° angle to the pistons of a 90° elbow engine at the center of each elbow.
I have done a fair amount of experimentation with that type. It is easy to change the angle of a swash plate and it can be done by changing only one simple part. I have used swash plate angles as close as 15° that correspond to a 165° elbow but I have settled on a 20° swash plate angle as a good compromise. That is not far from the 22.5° geometry of a 135° elbow.
So many options, so little time.
Jerry
Jerry
