Hilmar, I made the crank from solid excepting the counter weights which are attached. I destroyed both the silver solder crank blank that came with it and the cast iron counter weights. Weights cracked when peening them on.
Made a new set from steel, worked perfectly. Ill post a pic of the pretzel, er first crank, but its on a computer sans motherboard at the moment.
Come on man, I need you to work through that problem and get back on course - there may be other nasty bits I need you show me how to made
Ok progress pics. In the previous post, the pics show the oil cups I made for the main bearings, but I felt eccentric straps and big ends should also have some way of delivering oil.
Here are the little cups I made for the eccentrics, the small OD is 1/16, the six are sitting on a dime.
Heres a shot of them installed - its triple so there's 3 or 6 of everything!
The big ends required a bit more thought as the counter weights narrow in on the connecting rod once the bearing is cleared you can see that in the pic of the crankshaft above
So I decided to have a base, pipe and cup at the top and to twist it around to the side so it would clear the counter weight.
Here are the parts are being assembled. The brass tube is only .047 OD and thats #67 reamer to clean out the brass tube ID after cutting. You can see the visor magnifier in the background that gives me a fighting chance on these parts
And here they are installed Incidentally, the geometry formed by the tapered connecting rod where it meets the U shape at the top was one very challenging aspect of this engine the parts have to blend together with a radius to look right. Maybe a five axis cnc? Still would require hand work to blend it me thinks. This was a close to sculpting as my machining as ever come, tedious needle file and emery work!
The cup had to be where it is to clear the counter weights and looks somewhat like prototypical practice
More fun and games today, put engines a side and spent the day tuning up a Starrett #20 master precision squares and M&W #400 long day, now I know why the cost so much new
