- Jun 4, 2008
- 3,292
- 635
The plastic shaft on the wire speed knob for my welder broke off after 5+ years of use, meaning I needed to also replace the cheap potentiometer with a better quality metal one. Needing a knob, I decided to fab one from a bit of aluminum rod. So I turned a 1" spigot in one end of a cutoff from some 1.25" rod, and mounted in the collet chuck. Turned/faced/chamfered as shown:
Moving the same 5C collet to the hex collet block on the mill, I drilled and tapped a 5-40 hole for a set screw:
Then with the collet block vertical, I used a 1/4" ballnose mill to create 6 flutes around the perimeter. Finally used a 1/16" endmill to scribe an indicator line on the top:
Then returned to the lathe to remove the spigot and polish a bit with some scotchbrite. Here's the result on the new potentiometer:
About 90 minutes start to finish.
