lee webster
I was invited to watch a pour of cast iron where glass scrap was used to fuse to the dross and make the pour cleaner. I dont know about brass.
Pretty much any metal can soak up some hydrogen from the furnace environment, copper alloys will also pick up oxygen (adding phosphorus removes this).I also recall having gas issues (no pun intended) with brass.
Holding a metal at an elevated temperature often causes absorption of gasses, and I could clearly see small gas bubbles all through my brass casting.
I have seen brass degassing agent for sale.
Don't breath any fumes coming off of any degassing agents.
Edit:
One of the benefits of melting gray iron is that it does not seem to have gas absorption problems, for whatever reason.
Hmm. All the contributors here who regularly cast iron can comment on this. I personally have never heard of glass being used on iron.
Correct me if I'm wrong.
In practice however most of the porosity in a typical hobbyist casting is caused by entraining air in the pour. You can avoid that with good gating system design. Since adopting a tapered sprue with pouring cup and gates sized for a controlled fill rate (to avoid turbulence) I've consistently had relatively little porosity in my aluminium castings.
A side note: the chemical bonding in the metal is so strong that a gas bubble can't really form from dissolved gases unless there is an existing weakspot in the material. Typically this is an 'oxide film' formed by the oxidised surface of the pour getting mixed into the bulk metal. Even the best castings are full of these, they also act as crack initiation points which is why castings are typically less ductile and have lower ultimate tensile strength compared to wrought materials, even when their alloy composition is similar.
I've got a fairly spectacular case in an ingot I could show (just need to go the the shop and take a photo, but that will have to wait until tomorrow). I'm fairly sure a large portion of it is air entrainment however, as my casting practice at the time was total garbage. There are certainly pinholes as well, not a shock given how dirty the metal was.Looking through my photos, I can't really find a good example of gassing in aluminum castings, but I recall having tiny pinholes in my early aluminum castings.
If you don't measure the aluminum temperature carefully, and if you don't pour immediately when you reach pour temperature (about 1,350 F), then you can get the pinholes.
The pinholes may not be noticeable to the untrained eye, but I did notice them in my early castings, expecially when I let the metal temperature overshoot (due to not paying attention), and letting the aluminum stay at or above pour temperature for perhaps 10 minutes.
The pinholes don't seem to affect the structural integrity of the aluminum 356 casting, but I have heard that for air-tight applications, such as a pressure vessel, you want to avoid the pinholes.
I have never used glass as a flux with cast iron but I always use glass when melting brass. If you use clean cast iron there is not much slag formed and it is easy to remove.Hmm. All the contributors here who regularly cast iron can comment on this. I personally have never heard of glass being used on iron.
More like crumbling up palm fat on top, before you put the hot soup into the fridgeso on the glass, what do they actually use? broken up glass jars and bottles that are clean and dry? kind of like crumbling up saltine crackers before putting them on top of a bowl of soup? - now i want a bowl of tomato soup.....
I use any kind of glass color does not matter. It is added when the crucible is cold and full of scrap brass. It floats to the top and protects the molten brass from burning zinc.so on the glass, what do they actually use?
I was told that if you had pinholes in a casting you could Teflon impregnate to reduce the pin holes. Is this correct?Looking through my photos, I can't really find a good example of gassing in aluminum castings, but I recall having tiny pinholes in my early aluminum castings.
I,m a bit late om this, but there is a filament for casting moulds.MoldLay sold by 3dprima.question about lost pla casting - often i will use red filler primer or heavy scratch primer to get rid of the print lines and make a smooth looking 3d print.
will that stuff burn out with the pla in my mold or will it leave a shell like a sheetrock mud coat might do ? thought about just plain parifin wax and painting it on the outside however i have warped pla prints with hot wax before so wanted to use the primer if it will burn out.
want to use plaster as the mold material, burn out the pla and hopefully the primer as well.
Does swarf melt without excessive oxidation - Slag? Or should I sell to the scrap man?
Dubi
Bengt
