Here's a query for this forum's community:
My project calls for restoring the threads of a hole in a housing made of diecast zinc - I intend to drill out the hole's damaged threads in the housing then inserting a threaded sleeve made of brass. Caveat: Once I drill out the damaged threads, there'll be only a wall thickness on two sides of no more than 1/8" - That's where a potential structural failure may occur if the expansion ratio of these two metals is very different.
Whatever the diameter of the drilled out hole in the diecast zinc housing will be, the insert's O.D. will be slightly larger - This, because I intend to freeze the brass insert, to reduce its diameter slightly before inserting it into the drilled out hole.
My hope is to let the insert expand at room temperature in the hole hopefully seizing the insert in place, with the expectation that the brass threads of the insert will outlast the original zinc-diecast threads of the housing.
I'll appreciate any and all input, critical or helpful, as to whether I'll have a structural failure once the insert is in place and begins to thaw at room temperature.
I will gladly clarify further if needed.
Many thanks!
Many thanks!
