- Jan 4, 2011
- 1,418
- 384
I have been playing around recently trying to add ignition systems to my existing engines. The thought is that I will probably try to sell some of them before my kids and grand kids get stuck with the job or just dump them. Most of the engines have been running with my "ignition box" which consists of a SLA battery, an automotive coil and condenser.
The CDI ignition is compact but beyond my capabilities. I have built a couple of transistor systems similar to TIM-6. The problem is the printed circuit board. Universal boards are available but making connections between components gets messy. bending the pins on the first component to the next component works but makes a messy board and does not always work when the components are far apart or multiple connections are required to the same point. Boards with traces between several tie points are available but it never seems to make for a neat solution. I have tried to make solder bridges between points but that does not work well. The solution would be to make custom boards.
First question is: Is there a good way to make connections between components on a universal board other than soldering to the pins on the bottom of the board?
Second question: I have a small Grizzly CNC mill which I would assume could be used to make custom boards. Copper clad sheets are available and I assume that removing the copper where you do not want traces is the way it is done. It is like making a statue where you start out with a block of marble and remove everything which does not look like a horse. There seem to be software programs which can produce circuit boards. Some are free and some are way beyond a price range for the home shop.
Any pointers on how to proceed as far as setting up the mill or how to proceed with a software program are welcome. Am I missing something? Should I be looking at etching for boards?
I am aware of the fact that there are companies who will make boards for a reasonable price. I am looking at this as a learning experience as much as just a way to get results. Obviously I do not want to spend a lot of money and would like to use existing equipment if possible.
Thanks: Gordon
Thanks: Gordon
