- Jan 4, 2011
- 1,435
- 401
I have been building the Potty three cylinder which has free plans on this site. This was built as a team build a couple of years ago.
I have a question on the return crank (Item 19) on the pin which actually drives the orbital valve. In the photos on the team build it shows the pin in the brass prototype in a position looking at the pin end as being left an below center and the final pieces being right and below center. I have made it right and below but it does not work as I think it should. The flywheel would have to run CCW in order to work and that loosens up the nut holding on the flywheel. It would seem like it should be 180° off from that. Am I missing something or did I do something wrong?
I certainly have something wrong because I cannot even get it to try to run in either direction. I even tried cutting another slot in the face which makes it like I think that it should be but still it does not run.
