Naiveambition
- May 15, 2012
- 369
- 95
Hey everyone. Been going thru the trials of getting my poppin to run and have a few questions I hope can be answered.
When setting the cam it states 15 degrees before tdc. So do you use the centerline of the cam, or is it the leading edge of the cam, meaning at 15' does the valve just start to close.? Look at pic, it's set to just start closing valve now, with counter clockwise rotation.
I'm on the understanding that a vacuum is created at rear tdc that pulls the piston back to next stroke, and flywheel helps make it past front tdc.
So far it sounds like a sick duck, it feels really close like it wants to run, but no luck, even when too hot to touch, so I don't think it a heat problem. Rolls over nicely with almost no resistance. I have honed the cylinder tonite and fixed a leak in cylinder cap. Pulls a nice vacuum against the cylinder, with the pop coming out of cylinder. Am using Coleman fuel. Any help is greatly appreciated
