StretchNutsTheClown
Apologies for quality of sketch, I got a moment of inspiration and have to get it out there as quick as I can before procrastination takes over and I think about something else.
The intended purpose of the machine is to get heat from outside to the house. Wife didn't want a wood burning stove, I did because electricity is expensive here and unreliable. The compromise was a burner outside and radiators indoors. Marriage is all about compromise.
The boiler in the left, creates steam, heats the heat exchanger that provides the hot water radiator circuit for the house (although now I think the heat exchanger should be AFTER the turbo). The stream then turns the turbo. The stream then travels to the radiator from a tractor where it will have cold air blown over it from the air intake side of the turbo, the hot air extracted from the radiator will then be ducted and circulated to the house. Hopefully this will be enough to fully condensate the stream so it can be returned to the boiler.
I added the next part after as to not further confuddle my already terrible sketch. Rather than have an electric water pump inside the house, I'm looking at modifying the turbo and extending the shaft out so I can add a pulley to power a water pump for the radiator circuit.
I'd appreciate some feedback. I'm struggling with calculations on how big I'll need my boiler and how much much work the turbine will need to do to move the air and turn the pulley for the water pump. Also, is it possible to to have the steam/reclamation on a fully closed system? (with pressure release valves everywhere!)
Omitted are systems for cooling and recirculation of oil for turbo
Main considerations for design are reclamation and recycling of water used for steam and use of turbine rather than engine as it starts itself and I have a tonne of turbos in my shed.
Thanks in advance
Thanks in advance
