Hi all! Please excuse me this is my first time posting here on the forums. I am currently building a Alpha-type Stirling engine based off the Alpha Victory by IronHorse. You can read it here at http://www.homemodelenginemachinist.com/f31/alphavictory-engine-build-8343/
I have built most of the components and I am currently attempting to joining the brass pipes and the regenerator by silver soldering/brazing. Joining metals by heat isn't my forte unfortunately and i have a lot to learn. :wall:
I am currently confused as to the differences in silver soldering and silver brazing. Sometimes the terms seemed to be used interchangeably sometimes they seem worlds apart.
I need to produce air tight joins between, brass and brass. aluminium and brass as well as 303 stainless and brass.
Currently I have attempted by to no success in trying to join brass to brass. Only resulting in a melted brass tube which was supposed to be my regenerator. :fan:
I am equipped with the following: BernzOmatic TS8000 torch using MAPP
BernzOmatic Nickel Silver Brazing Rods
Durafix aluminium soldering/brazing rods
Ezi-weld 602 flux
Are these items sufficient to get the job done or have I bought the wrong items.
Any advice would be appreciated!! Thanks
Ezi-weld 602 flux
