Pistons positions
PeterB
Hello
Can somebody explain to me the Pistons different positions like TDC, TDP and so on.
Thanks
Hello
Thanks
TDC=top dead centre--- top off the stroke
BDC=bottom dead centre ---bottom of stroke
TDP ???????? Don't have a clue
TDP ???????? Don't have a clue[/QUOTE said:
TDP piston seal made with viton or NBR
piston for cylinders with oil "hydro"
Jan Ridders wrote TDP on his site but it's maybe just a misspelling.
Where shall an ignition take place? Just before TDC or exactly on TDC or just after TDC?
with the type of engine Jan build he's probably TDP type
usually before but your engine configuration will determine what's the best time before TDC
Usually just be fore TDC, ie 2 degrees or you can measure with a dial gauge from the top of the bore at x value.
Rather than post unnecessary information about seals etc, and get it all wrong, and then get upset, I read Jan's site and realise that he means Top Dead Position. Quoting from the site, "Put the piston in it's highest position (TDP)". Of course, it means the same as TDC, but allowances have to be made when English is not the native language. I hope that this was useful.
Paul.
