- Jan 4, 2011
- 1,418
- 384
In the past there was a company which sold piston rings for small engines. I believe that the company is no longer around. Is there another company where it is possible to purchase piston rings?
GUS: To what heat treatment are you referring? I've made many and never heat treated them?? Always ready to learn.
One way of making rings is to bore, turn, and part off to size. Then the ring is cracked apart and put on a fixture to hold them open. Then they are heated to stress relieve them. When taken out of the fixture they stay open and need to be forced closed.
A clamping jig is required to hold the stack of 3---4 rings tight. Heat to cherry red and hold for min. of 5 mins and quench in water. View Paul's thread.
Paul Swifty, Please audit.
Gus, I just let mine cool naturally, as slow as possible would probably give the best results, we don't want to introduce any stress to the rings.
Paul.
Yes. For sure you DO NOT want to quench them. I'm surprised they haven't cracked. Hopefully they won't do so in the engine. You are actually trying to relieve the stress put into them by stretching the gap open so the gap remains set in the new position.
Sage
SWIFTY: Very interesting method, Next time I make rings I'll try your method. Since you guys in Aus. are upside down I guess you see things differently. ;D
Does anyone worry about the lack of a gap for heat expansion? I try to leave a few Thou.
