adolfgalland
- Jul 12, 2014
- 19
- 16
I have used Delrin on air powered engines with good results. Its coefficient of expansion is about 40 percent more that Ertalyte but for a comparison Teflon is 200 percent more. Many of my engines are small and I use the Delrin mostly on bores of 3/8 inch or less. On the larger (up to one inch) I use Ertalyte. Engines run good with out blowby and again no need to lubricate. None of these plastice are good in wet environments if you have close tolerances. Photo of very small Radial with 1/4 inch bore Delrin pistons. Runs good. Gary
