Johan Maritz
Active Member
Hi to you all. I'm in the very final stages of my Elmer Verburg no 29 engine. I need to machine the piston. I made the cylinder out of brass. I was thinking in the direction of making the piston out of cast iron. Not sure if this is a good combination, i must add that i doubt i will ever run it on steam. It will most probably only run on compressed air. Then i started thinking in the direction of teflon ( vesconite) for piston material. Would that be a good combination with the brass cylinder? Any other suggestions. By the way, my hat off for people who has build this engine. This was seriously challenging in terms of very small fiddly parts.
Johan
Johan
