I dont have a good way to make a really smooth cylinder or piston surface finish wise. Have any of you found a good premade cylinder or piston? Preferably it would be more in a stock form where I could cut it to length but beggars cant be choosers. I thought about things like drill bushings but is there anything else out there that you have found? How about some kind of pipe that has a pretty good inside finish that I may could just use a cylinder hone on?
I think I could probably make a piston since its a little undersize but thought would throw that out there if anyone found something good to use for one. Do any of you use some type of metal rings, precision fit or is a o-ring the more common seal? you would have to cut a deep groove but maybe even a backup ring could work.
My application would be more in the steam, compressed air and CO2 realm.
